Decrypt Backups
Overview
Cloudron supports encryption of backups with a passphrase. In this guide, we will see how to decrypt Cloudron backups on your laptop/PC.
Prerequisites
Have your PC/laptop setup with the Cloudron CLI tool. You can do this by sudo npm install -g cloudron.
Then, login using cloudron login my.example.com.
Download backup
This guide assumes you have the backup downloaded locally. If not, see this guide.
Decrypt
tgz
If the backup format is tgz, the download will be a single file with the extension .tar.gz.enc.
$ cloudron backup decrypt --password=passphrase backupid.tar.gz.enc backupid.tar.gz
$ tar zxvf backupid.tar.gz
rsync
If the backup format is rsync, the download will just be a directory.
$ mkdir /path/to/unencrypted
$ cloudron backup decrypt-dir --password=passphrase /path/to/encrypted /path/to/unencrypted
