Connect to MySQL Addon
Overview
Apps on Cloudron use an internal MySQL database (addon). For security reasons, the database is only accessible from inside the server and cannot be accessed directly from outside. Instead, the database is accessed using an SSH tunnel to the server.
In this guide, we will see how to connect to the MySQL addon database from outside (say, your laptop/PC).
Database credentials
To get the database credentials, open the Web terminal of an app and run env | grep CLOUDRON_MYSQL. Make a note of the credentials. Note that each app has it's own separate database and thus it's own database credentials.
Internal IP Address
The internal IP address of the MySQL server is 172.18.30.1.
DB Clients
CLI
To connect via MySQL CLI, open a Web Terminal and click the MySQL button at the top. This will paste the CLI connection command into the Web Terminal. Press enter to execute the command and use the CLI.
DBeaver
DBeaver is a free multi-platform database tool for developers, database administrators. You can download it here.
Create a new MySQL connection in DBeaver.
Fill up the values gathered in the steps above:
Configure SSH tunnel by clicking on the SSH tab:
You should now be able to view the database:
MySQL Workbench
MySQL Workbench is a unified visual tool for database architects, developers, and DBAs.
Create a new connection in MySQL workbench.
Select Standard TCP/IP over SSH as the connection method. Fill up the values gathered in the steps above:
